ECU Mods 2009 Accord Coupe V-6
Old Feb 12, 2013 | 06:48 AM
AccordCoupe09's Avatar
From: Seminole, AL across the Perdido River from Pensacola, FL
Default ECU Mods 2009 Accord Coupe V-6
Hi All:
I have made the following upgrades in the Engine Management System:
Jet Products Hi-Flow Mass Air Flow Sensor (MAF / MAP)
Jet Products V-Force Plus Performance Module - provides mild progamming and LCD read-out of many engine performance parameters including battery charging and gas mileage efficiency. Per Jet dyno figures, Sensor and Performance Module 5+ HP and 3+ FPT
Jet Products Re-flash of OEM Engine Control Unit (ECU / PCM). Per Jet dyno figures using 89 octane minimum 12+ HP and 14+ FPT with unknown additional HP and FPT enhancement by optimizing the other intake and exhaust modifications noted in other sections of the forum.
I will be doing a dyno run this Friday using 93 octane 100% gas (no power robbing mileage reducing ethanol garbage) and will post results in the dyno section. I will then try and do any tuning tweaks available based on those initial results.
4drEF
Aug 24, 2012 06:07 AM
Fabman
Sep 21, 2006 07:40 PM
BadPing
Nov 8, 2004 08:33 PM
petrv
Nov 4, 2003 12:49 PM
