Center console removal
Old Feb 11, 2013 | 03:11 PM
eagle458's Avatar
Default Center console removal
Does anyone have a procedure for removing the console around the shifter in a 1996 Accord V6 automatic? My light is burned out.
Old Feb 11, 2013 | 05:19 PM
Jmb106jr's Avatar
Default Re: Center console removal
first remove the cup holder, there is one screw up near the gear selector, remove it you do not need to remove the bottom 2 screws, then open up the arm rest and empty everything out , at the bottom of the arm rest there is a door , with a small flat blade screw driver open it, remove the 2 screws. pull the e brake handle up, pull the whole arm rest/center console towards the back seat, then lift it up over the e brake handle.Remove the 2 screws that hold the radio/gear shift bezel, next remove the ash tray there is a screw behind it remove it. thats all the screws that need to be removed. now gently lift up the bezel and pull it away from the radio you will have to unplug the flashers and the clock, there is also a plug under the bezel for the Cig lighter that you unplug.takes about 5 mins to remove.
Old Feb 11, 2013 | 06:14 PM
dnguyen2010's Avatar
I'm sure there is a video on youtube.
Old Feb 12, 2013 | 12:39 PM
eagle458's Avatar
Awesome! thanks!
graham_ott
Honda Civic (2001 - 2005)
Jun 29, 2015 10:12 AM
mgalpy
May 13, 2007 07:41 PM
allmotorls95
Jan 14, 2003 10:15 AM
TypeRPinoY
Nov 28, 2002 07:57 PM
Judah
Nov 21, 2001 08:22 AM
