Finished build & now looking into a hondata s300.
I've never posted in this section before so please forgive the noob question.
My build consists of:I/H/E/IM/70MM TB/S2 TUNER 1'S/adj cam gears and a chipped(basemap) p28ecu
94 B18C1 with stock comp 220-230 across all 4cyl.
my question is with this mild/med setup could i benifit from a hondata s300 or could my money be put to better use(coilovers)
thanks in advance
thanks in advance
Where did you get your basemap? At the level of build you have I wouldn't trust a basemap for too long. I/H/E with cams is definitely a candidate for proper tuning.
If you're considering an S300 I recommend you also look into NepTune RTP.
from a place called Teknotik VERY reputable in the Toronto area. and i would be getting them to do the tuning if i get a s300/neptune rtp. as far as hondata vs neptune im not sure i'll be talking to them in the spring(car is stored for winter).
honestly id spend the money elsewhere wait for tuning when you get cams headwork or raise compression(mill/thin headgasket) stuff along those lines. just my input.
The answer to this really depends on what tuning software your EXPERIENCED local tuners support/use. A lot of shops will only tune specific software/ecus etc.
