97 Accord, front end shake at speed around 2k
While driving, using the pedal to keep speed, I get shake from the front at about 2k rpm. If I let off the gas, it goes away (even at 2k), and some times its bad, and others its not. Any ideas on what is causing it, or is this a common issue?
Where do you notice the shake? Is it in the steering wheel? Is it worse at certain ground speeds or is it clearly related to engine speed? In other words, does it happen around 2K regardless of what gear the transmission is in?
Can you provide more detail on the pattern of behavior?
... some times its bad, and others its not.
Also, under heavy acceleration does this go away?
Instead of letting off the gas, what happens if you give it more (higher rpms)?
