****The under $50 Sale. come get it!****
Old Feb 10, 2013 | 11:14 PM
My_EFsedan's Avatar
Default ****The under $50 Sale. come get it!****
Alright so Dad had me clean my area of the backyard. ive already thrown a ton of things away but here are some items i think can be a use to someone.
Im free after 4:30pm and both sat/sun.
Best contact would be my phone here @ 408 318 928zero.
1) G35 sedan tein springs. they were cut a tad bit more so it goes pretty low. ride quality is not bad, but not great. $25
2) inside the box are the Stock G35 springs. $35
3) 96-00 civic sedan CUT springs. they were on my sisters sedan which was pretty low BUT RIDES LIKE STOCK GUARANTEED. $20
4) Stock 88-91 civic WAGON shocks. one has top hats off but i still have it. not blown. (brother has these on his eg with gc coilovers, rides amazing!) $40
5) EF5 / Wagon Front radiator support. came off my RHD front clip. not bent. no T-bar. $45
6) 97 B20 Head from NCAS when i bought it. ~40-45k mines. complete. will throw in LS manifold if bought (#7) used block as b20vtec. $50
7) Stock LS manifold has nothing on it. $15
8) 96-01 BMW? will double check. STOCK tail lights. Clean. was swapped out for clear/red. $40
9) Front Mud gauges for either dc or eg, cant tell. $15
10) JDM B16 Timing cover upper half front and back. $15
11) R6? stock Exhaust brother bought a bike with a yoshimura exhaust and this one. $40
12) N1 Style exhaust. welded to fit an EK also have silencer $20
13) LS/B20 VC $15
14) LS VC $15
15) stock replacement exhaust. came with my wagon. said it was new, but i replaced it with a vibrant. 2' in/out $20
16) stock SOHC header. cousin went turbo on his d16z6 ferio. $30
17) Stock replacement Exhaust box. almost new. has a small hole but affects nothing. 2.25 in and 2.5 out. $30
18) 93 dodge caravan radiator, brand new. has fan and cooler. $45
19) 88-91 SEDAN front filler piece between the hood and metal filler. $10
20) ebay half rad. was in my EF. has a slight fin cut at the bottom. leaks coolant a bit. quick epoxy or a quick 1sec aluminum weld will fix it. $25
88-91 SEDAN fender. one minor dent. paint is still clean. (bought @63 -.-) $30
BNIB Exedy replacement clutch. its for 88' civic trans ONLY! smallest spline. bought for my uncles car but his car was an 89 so the clutch just didnt fit. never used. $45
EG rear mud flaps. clean just super dirty. markings are SH4 L RR/LL $40
BNIB OEM brake pads for:
ACCORD 2002 2DR EX (V6) KA 4AT
ACCORD 2002 2DR LX (V6) KA 4AT
ACCORD 2002 4DR EX (V6) KA 4AT
ACCORD 2002 4DR LX (V6) KA 4AT
ACCORD 2001 2DR EX (V6) KA 4AT
ACCORD 2001 2DR LX (V6) KA 4AT
ACCORD 2001 4DR EXV6 KA 4AT
ACCORD 2001 4DR LXV6 KA 4AT
ACCORD 2000 2DR EX (V6) KA 4AT
ACCORD 2000 2DR LX (V6) KA 4AT
ACCORD 2000 4DR EXV6 KA 4AT
ACCORD 2000 4DR LXV6 KA 4AT
ACCORD 1999 2DR EX (V6) KA 4AT
ACCORD 1999 2DR EX (V6) KL 4AT
ACCORD 1999 2DR LX (V6) KA 4AT
ACCORD 1999 2DR LX (V6) KL 4AT
ACCORD 1999 4DR EXV6 KA 4AT
ACCORD 1999 4DR EXV6 KL 4AT
ACCORD 1999 4DR LXV6 KA 4AT
ACCORD 1999 4DR LXV6 KL 4AT
$25
PM6 88-91 Civic/CRX SOHC Si ECU. worked when i used it. sat for several years. $45
Complete Z6 intake manifold. missing is 1 12mm bolt to IACV and no IAC sensor. otherwise, rail, injector, tb, tps, map, fuel line is there. $45
1) ACT pressure plate. unsure of which one. surface rust $10
2) Clutch Master pressure plate. surface rust $10
Yakama Bike rack in pieces. what you see is what you get. the side locks all messed up and such. $25
1) Autozone intake 3' $10
2) DA automatic cluster $15
3) STOCK DX EF ecu. nice for DIY obd0-obd1 conversion $10
Old Feb 11, 2013 | 09:53 PM
My_EFsedan's Avatar
Default Re: ****The under $50 Sale. come get it!****
really dont want to toss these items!
Old Feb 17, 2013 | 02:58 AM
Rickdogg's Avatar
txt sent about b20
promotor
Honda S2000
16
Apr 20, 2010 07:54 AM
green99civic
Jul 16, 2009 11:48 AM
GReddy_Civic
Suspension & Brakes
Nov 30, 2007 07:19 AM
kyorishin
Jan 29, 2006 10:15 PM
EIT_certified
Aug 13, 2004 09:46 AM
