obdo sir1 b16a all motor set up
Old Feb 10, 2013 | 06:31 PM
Jason Nucom's Avatar
Default obdo sir1 b16a all motor set up
Planning to work on this all summer this year, its a stock b16a with 2.5 magnaflow exhause /w short ram air intake.
what's a good setup for this motor, for an all motor setup.
Old Feb 10, 2013 | 11:18 PM
ryanangelo212's Avatar
Default Re: obdo sir1 b16a all motor set up
Edit your post and be a little more specific, otherwise you'll probably get some flames haha.
What are your goals, which direction do you want to go, what's your budget, why n/a over forced induction?
Old Feb 11, 2013 | 01:59 AM
skill178's Avatar
For a N/A build, High Compression pistons, cams valves valve springs, ect. if your any good with fabrication you could go ITB (individual throttle body's) get some adjustable cam gears and a full upgrade on the ignition and have it tuned. not too much to do to an engine in all honesty.
pistons-rods-valve train-ignition-fuel delivery..
Old Feb 11, 2013 | 07:43 AM
BLU CIVIC's Avatar
Track Advocate
instagram on your valve cover?
buddy190
Feb 15, 2009 03:30 PM
HCivicSi23
Nov 26, 2007 11:03 AM
chancock
Aug 23, 2007 12:31 PM
MrPink96
Jun 26, 2005 08:15 AM
