clutch suggestions?
Old Feb 10, 2013 | 05:55 PM
91grape's Avatar
Default clutch suggestions?
just got my ek the other day, and the pilot bearing is squealing bad. when i go in to replace it i wanted to do the clutch flywheel etc. ive googled and looked around and all seem decent but what is a preferred and dependable brand?
Old Feb 10, 2013 | 06:16 PM
doood's Avatar
been there done that
Default Re: clutch suggestions?
exedy oem
Old Feb 10, 2013 | 07:19 PM
dirty19's Avatar
Ridin Dirty in Cali
Really you googled and found absolutely nothing?
Didnt we just do another one of these clutch opinions just days ago?
Whats that make 20 for the first month and part of feb?
Old Feb 10, 2013 | 08:05 PM
Emeraldbomber's Avatar
Exedy like Doood said. Been running mine for 2 years been beat the crap out of time and time again and operates like I just put it in.
Old Feb 10, 2013 | 08:45 PM
Former User's Avatar
Just curious about how you know the pilot bearing is squealing?
Old Feb 11, 2013 | 12:02 AM
G_thirty_5's Avatar
Act or compitition clutch.. couple of the best... and i don't think its your pilot bearing. It wouldn't squeal It'll chatter if anything. I think its your clutch slave sqeeking hen u push in your clutch. That nhing major u can run it like that or could be your throw out bearing
Old Feb 11, 2013 | 05:14 AM
1feocrx's Avatar
their is alot of clutch companys how can you not find one. act clutch masters exedy ,
Old Feb 11, 2013 | 06:02 AM
91grape's Avatar
I never said I didn't find anything, I was wondering of a preferred brand and what's more dependable. And I suspected the pilot bearing because it squeals and stops when I press the clutch.
Old Feb 11, 2013 | 06:07 AM
I don't think this^ is consistent with a bad pilot bearing. It sounds more like a transmission bearing problem.
Old Feb 11, 2013 | 09:02 AM
Psychoteen101's Avatar
^ Or a bad throw out bearing will cause this. Either way, the trans has to come out to check either possibility.
Old Feb 11, 2013 | 09:12 AM
Ryan96GSR's Avatar
ISB like ron said sounds more like the kulprit. Noise with your foot off the pedal is the ISB, noise once you are on the pedal is TOB.
The ISB will also cause noise while you are moving in gear.
Old Feb 11, 2013 | 09:25 AM
91grape's Avatar
yeah like psychoteen said, the trans has to come out either way, and ill replace it all then anyways. but i read some reviews on exedy, ill probably go with them unless i find another decent brandand while im at it im gonna look for a lightweight flywheel as well. thanks.
Old Feb 11, 2013 | 09:27 AM
The point is that your clutch/flywheel may be fine and the problem instead likely lies inside the transmission.
Old Feb 11, 2013 | 09:44 AM
G_thirty_5's Avatar
I HIGHLY DOUGHT ITS THE TRANS.. SOUNDS MORE LIKE THE THROW OUT BEARING
Old Feb 11, 2013 | 10:03 AM
Ryan96GSR's Avatar
The symptoms point to the ISB and not the TOB.
Like the OP said, the noise stops once he pushes the pedal to the floor. the TOB would cause noise under those conditions.
OP please post a video if you can, that will give us a better indication of what exacty is happening.
Exedy is what I would suggest. it's essentially honda OEM. That or a stage 1.
Old Feb 11, 2013 | 10:55 AM
If you understand how the clutch works, this^ makes no sense.
MiNeSEK
19
May 11, 2013 12:05 AM
anewfoundkevin
Jul 12, 2010 02:25 AM
ericlee303
Sep 8, 2007 11:34 AM
lswantsvtec
Jun 25, 2007 09:37 PM
Heinz57
16
Dec 29, 2005 07:00 PM
