2 Questions....Exhaust and resonator related
Old Oct 21, 2002 | 08:04 AM
cruzersi99's Avatar
Default 2 Questions....Exhaust and resonator related
1. Does anyone know the size of the stock ITR resonator? How does this resonator compare to an aftermarket piece?
2. I currently have a 5zigen Fireball Exhaust. But, now that everyone and there mother has one, I wanted to change mufflers. The piping on the 5zigen is 60mm, but most aftermarket mufflers like Maganflow and ES only come in 2.25" or 2.5". Would it be better to go to the smaller 2.25" and create a small restriction or would it be best to go to the 2.5" and lose velocity?
Thanks in advance,
Cruzer
Old Oct 21, 2002 | 08:14 AM
Rob :190:'s Avatar
Default Re: 2 Questions....Exhaust and resonator related (cruzersi00)
depends on the rest of your mods and how extensive they are.
Old Oct 21, 2002 | 08:16 AM
(__________)'s Avatar
Default Re: 2 Questions....Exhaust and resonator related (Rob :190:)
What other mods do you have and what are your future plans?
Old Oct 21, 2002 | 08:34 AM
cruzersi99's Avatar
Here are my mods: b16a (99 Civic SI), CTR CAMS, ITR Valvetrain, 11:1 Compression, ITR Intake Manifold, Spoon TB, Comptech Icebox, JDM 4-1 Header, 5 Zigen Fireball exhaust.
I dynoed 167 whp. I already have the ITR resonator attached to my 5zigen piping, because the original resonator cracked after only a few months. I don't plan on doing too much more in terms of modifications.
I am getting ready to put on a Carsound Hi-Flow cat (2.5") and was planning on running that through my current piping to save money. I also don't think that I need 2.5" piping all the way back. But, if the ITR resonator that is currently on my 60mm piping is creating a resriction or a loss of velocity due to unmatched piping size (too small or too big), then I was considering getting the 2.5" Carsound with 2.5" piping running to a magnaflow 18" x 2.5" and then connecting that to my 60mm piping.
I guess here are the options in order of least expensive to most expensive:
1. 2.5" Carsound Cat--->60mm 5Zigen Piping/ITR resonator---->2.25" Magnaflow/ES
2. 2.5" Carsound Cat--->60mm 5Zigne Piping/ITR resonator--->2.5" Magnaflow/ES
3. 2.5" Carsound Cat--->2.5" Magnaflow Resonator--->60mm 5Zigne Axleback Piping--->2.25" Mangaflow/ES or 2.5" Magnaflow/ES
4. Brand new 2.5 inch system all the way back
Sorry for the long post everyone. What do you all think. I don't really want to spend all the money on the 2.5 inch system. One because I think it may be too big, and two because it is more expensive. But if the other systems will be also be creating flow restrictions and decreasing horsepower than I guess I have no other option then the new 2.5" system.
Thanks again,
Cruzer
Old Oct 21, 2002 | 10:03 AM
Rob :190:'s Avatar
do the 2.5" carsound and a muffler shop 2.5" catback using the magnaflow, that will probably yeild the best results.
Old Oct 21, 2002 | 11:23 AM
cruzersi99's Avatar
Thanks for the input Rob. Anybody else?
Thanks in advance,
Cruzer
{Powered by VIII}
Apr 4, 2005 09:51 PM
rough_draft
Apr 27, 2004 08:58 PM
cruzersi99
Oct 21, 2002 07:14 PM
cruzersi99
Oct 15, 2002 01:02 PM
Mr. Softee
Jan 22, 2002 03:43 PM
