Ball Joint Removal
Old Feb 10, 2013 | 03:11 PM
BCGARAGE_ED7's Avatar
Default Ball Joint Removal
Do any of you guys have any tricks for separating the lower ball joints from the control arm? I currently use a tie rod separator and it works quick, but tends to rip the boot. What do you guys do in order to not rip the ball joint boot?
Old Feb 10, 2013 | 03:26 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Ball Joint Removal
what sort of tie rod separator are you using? what i use, which is a similar device to the honda tool, does not rip anything.
Old Feb 10, 2013 | 03:31 PM
'00DX_hatch's Avatar
He is probably using the fork style separater. i always thought you couldnt remove the lower ball joint bc it is pressed in.
Old Feb 10, 2013 | 03:51 PM
althemean's Avatar
I use the Harbor F separator. Like $20. http://www.harborfreight.com/3-4-qua...tor-99849.html
works like a champ. I redid all my ball joints when I installed the ES bushing kit.
Old Feb 10, 2013 | 03:54 PM
brizzle86's Avatar
Are you trying to replace the ball joint or are you just trying to free the ball joint from the knuckle?
Old Feb 10, 2013 | 03:55 PM
I was using the fork style removal tool.
Just trying to free the ball joint from the control arm.
Old Feb 10, 2013 | 03:57 PM
That's actually perfect. I'm going to go ahead and use that from now on. Thanks for the help, I appreciate it.
Old Feb 10, 2013 | 04:05 PM
the forks rip the boots, the link posted is what i use, works like a charm.
Old Feb 10, 2013 | 05:01 PM
All right sounds great. Thanks for all your help. Much appreciated.
Old Feb 10, 2013 | 07:36 PM
v4lu3s's Avatar
RTFM
i use a hammer and hit the lca.
Old Feb 10, 2013 | 11:15 PM
ryanangelo212's Avatar
^ Same, a few whacks with a hammer does the trick without even touching the boot.
Old Feb 10, 2013 | 11:33 PM
ef yu's Avatar
FREE and easy. well technically not free but you should have this tool or something similar if you're removing the ball joint.
Old Feb 11, 2013 | 01:47 AM
skill178's Avatar
smack the lca a few times with a good heavy hammer few good times unless you remove the joint often, after awhile the hammer method will start to leave impressions on the lca.
halocore
Mar 7, 2009 04:34 PM
89efhatchcrap
Suspension & Brakes
24
Feb 17, 2009 10:36 AM
M2nR
20
Mar 10, 2006 10:24 AM
2camsaam
21
Oct 1, 2003 07:32 PM
97hb
Mar 9, 2002 11:31 PM
