91 Civic SI backfires and bogs out
I have a 91 honda civic and it will start cold, but once it starts it backfires and bogs out, and will stall if it gets to low rpms. Once hot the engine wont start.
any ideas?
any ideas?
Could be a number of things, always start with the basics,is the check engine light on? do a basic inspection of the ignition system, take the distributor cap off, is it all fuzzy?(white crud built up on points) Check the rotor and see if its burned, is there oil inside of the distributor houseing? Pull a spark plug out see how it looks, could be a simple tune up issue could be something more
elchamakito
Apr 24, 2025 12:43 PM
civicsiguy21
Jan 10, 2014 02:33 PM
jbcrxsi
May 1, 2010 02:58 PM
Andy Lyons 91
Jun 27, 2007 06:21 PM
