Ect gauge in cluster not workin
Old Feb 9, 2013 | 06:13 PM
ShaneMoore's Avatar
Default Ect gauge in cluster not workin
Hey guys I just got a 2002 accord lx off. It had the engine swapped with the jdm h23a1. The ect gauge does not work and I don't know where the sensor is so that I can replace it with an external one? Any ideas?
Old Feb 9, 2013 | 06:33 PM
GhostAccord's Avatar
Default Re: Ect gauge in cluster not workin
The H23A1 uses the same style ECT sending unit that the original F23 used. The ECT sending unit is a single wire unit located under the distributor, mounted in the cylinder head. The wire may have disconnected, the connection or wire could be corroded or the gauge cluster could be faulty.
Just for clarification, the H23A1 is a USDM engine. The JDM engines only have 4 digits in the stamped engine code, H23A.
Old Feb 10, 2013 | 07:55 AM
poorman212's Avatar
I thought the '02 used the PCM for the coolant temp gauge?
Old Feb 10, 2013 | 08:41 AM
What ECU/PCM is the OP running?
Old Feb 10, 2013 | 10:54 AM
poorman212's Avatar
True, that we don't know. In stock set up the '00 and up use the PCM inputs for the coolant temp gauge.
Old Feb 11, 2013 | 05:40 AM
Shanemoore9's Avatar
Thanks for e quick replays. Sorry it took so long I had to make a new account but anyways I don't know what it is running but it is a single wire going to the ect sensor under the distributor. The previous owner wire tucked it with the rywire harness. The single wire going to the ect sending unit has no juice and I don't know why? It's also tuned on a hondata s300
Old Feb 11, 2013 | 05:43 AM
And you are correct it is the h23a out of the accord ch9 wagons from japan
jdm_ek_noob
Feb 5, 2014 04:57 AM
bighoss77
Jul 21, 2012 03:55 AM
deerman2701
Nov 16, 2008 04:09 PM
b16a1eg6
Oct 5, 2007 03:16 PM
