LCA and Subframe brace.
Old Feb 8, 2013 | 11:59 AM
HIallday's Avatar
Default LCA and Subframe brace.
I bought function 7's lca and subframe brace for my 95 Eg. Want to know if u need a extra part to install a lower arm bar or will it be a direct bolt on? I just don't wanna waste money buying the arm bar and I still need to get something that will make it fit. Lmk, thanks!
Old Feb 8, 2013 | 12:16 PM
grumblemarc's Avatar
The Grumpiest
Default Re: LCA and Subframe brace.
What do you need a lower arm bar for?
Old Feb 8, 2013 | 12:51 PM
cvcrcr99's Avatar
Buying a lower arm bar to use on your subframe brace is a waste of money in itself.
Old Feb 8, 2013 | 02:01 PM
alphalanos's Avatar
that brace will provide plenty of strength you do not need to add anything to it, it is not designed to have anything added to it either. so if you try to add something then yes you will probably need to customize it
Old Feb 8, 2013 | 02:15 PM
HIallday's Avatar
It was mainly for looks for a show but thanks for the advice tho!
dth0ng69
Suspension & Brakes
Dec 11, 2009 11:37 AM
TYL3R
Suspension & Brakes
Mar 14, 2009 12:33 PM
Blkcoupe
Oct 20, 2002 06:40 AM
