88 honda civic ef dpfi to mpfi problems
Old Feb 7, 2013 | 10:25 PM
88SIPROJECT's Avatar
Default 88 honda civic ef dpfi to mpfi problems
I have an 88 honda civic 3dr hatchback dx, and recently converted to mpfi,but i am having problems when i press on the gas pedal all the way. it starts up good and if i hit the throttle slowly their is no problem but when i try to hit the throttle fast it dies and it throws alot of white smoke. Any ideas?
Old Feb 8, 2013 | 05:15 AM
Red-Rocket's Avatar
Default Re: 88 honda civic ef dpfi to mpfi problems
Check your Throttle Position Sensor and see if you switched the two outer wires, DPFI and MPFI TPSs work in reverse of each other
Old Feb 8, 2013 | 06:41 AM
villc713's Avatar
what he^^^^ said
Old Feb 8, 2013 | 03:18 PM
I bought a plug in play engine harness so i think i should be switched around already
Old Feb 9, 2013 | 08:54 AM
I have tried to troubleshoot it a little. I tried checking the vacuum hoses, tried cleanning the throddle body,checking my ecu it has code 16 "injector plugs", i changed the injectors as well,clean the fuel rail,chaged my fuel filter,changed my spark plugs,checking my map sensor.
Old Feb 9, 2013 | 02:25 PM
ED3 SEDAN-GSR's Avatar
Did u get the whole engine harness or just an ecu jumper? If u just got a ecu jumper then u will stilll need to switch the two tps wires
Old Feb 10, 2013 | 04:26 PM
brizzle86's Avatar
Where did you get this harness from?
Old Feb 10, 2013 | 05:43 PM
24TEN's Avatar
PHANTOM MENACE
Originally Posted by 88SIPROJECT
...so i think i should be switched around already
Don't assume. It should only take you a couple of minutes to verify anyway.
Old Feb 12, 2013 | 10:03 PM
everything was ok i just had a ground wire loose ...F@^% hahahahhahaha
Old Feb 13, 2013 | 09:35 AM
24TEN's Avatar
PHANTOM MENACE
Glad to hear you got it sorted out. At least at the end it was an easy fix
Old Feb 15, 2013 | 08:00 PM
yea thanx everyone
Caskers
Feb 2, 2015 03:07 PM
Rigginit
Oct 19, 2010 09:01 PM
xisda1
11
Feb 5, 2006 10:25 AM
badboyr66
Dec 30, 2005 04:29 PM
JohnnieChimpo
16
Dec 20, 2004 09:23 AM
