Honda CR-V & Element 2WD & 4WD Element & CR-V
2000 crv front plate help
Old Feb 7, 2013 | 08:22 PM
EF001282's Avatar
Default 2000 crv front plate help
I just got a 2000 cr-v. I need to put a front license plate on it but there are some type of caps covering where the bolts would go and I cant get them off. I need to know how to get the caps removed. Also is there an oem bracket that I would need to mount the plate? I googled a bit but really only see cheap looking universal ones for sale. If any one can help I'd really appreciate it. I don't want to get a ticket for improper front plate.
Old Feb 8, 2013 | 05:10 AM
LDForget's Avatar
Default Re: 2000 crv front plate help
if you dont have an oem bracket, just screw the plate to those caps...
Old Feb 8, 2013 | 05:47 AM
FasterScooter's Avatar
F, it you're going to screw through the "plugs" I would make pilot holes with a small diameter drill bit first to avoid buggering-up your bumper cover. There is also a very simple lower bracket available from Honda I would advise you to pick-up, it does a great job of preventing the plate from curling around the bumper. Check the Majestic Honda website for a drawing and part #.
Old Feb 8, 2013 | 04:06 PM
EF001282's Avatar
thanks. found it, ordered it and it'll be here in two days
Dekorum
11
Jan 9, 2016 04:59 PM
manerd13
Honda Civic (2001 - 2005)
13
Dec 11, 2007 11:30 AM
o0oz
Jun 14, 2007 11:40 AM
z0om
Mar 24, 2004 09:15 PM
Mocky57
Honda S2000
Jun 5, 2003 08:22 PM
