what can cause a cam to break?
been there done that
long story short, my buddy texted me asking how something like this could have happened and i was at a loss. it's an 02 rsx-s with ~116k miles. only mods are an intake and exhaust, otherwise internally stock. oil level was good. i'm not there with him so i dont have all the details of what happened but from i can gather he downshifted from 6th to 5th on the freeway and the car died. he and another friend did a compression test and got super low numbers so they popped the valve cover and found this:
there are deep scratches on the cam caps and probably some bent valves too
Defective cam or possible driver abuse, is he an "aggresive" driver
Could be a valve bent that got stuck closed, how is the valve timing, did the timing belt skip some teeth? 94
he told me when they took off the valve cover the bolts holding cap #4 were loose. the cam snapped in cylinder 3. owned the car 3 years and never had a problem.
i wouldnt call him an aggressive driver. no more so than most honda drivers i guess.
Holy **** man, that sucks! As stated above, if they aren't torqued down in sequence or per torque spec, they'll snap like twigs. Looks like the #4 cap being loose caused undesired stress on the cam. I watched a friend snap a $600 HKS cam in a 2JZ on an engine stand a few years ago because he thought he was a badass and didn't need to follow the sequence.
Additionally, I have never heard of a cam breaking because of "aggressive driving"...
i was thinking maybe the cam breaking caused the loose bolts but who knows? it's odd though that after 3 years of ownership and never once removing the cams those bolts would decide to work their way loose now.
I'm thinking the bolts on the cap backed out causing the cam to snap. I'd maybe search to see if any other DC5 owners have experienced this or maybe if there was even a recall?
It wouldn't surprise me if someone DID loosen those bolts. Sometimes we make mistakes without realizing it. Maybe someone loosened it by mistake and didnt tighten it down well enough. Point is that the cam breaking wouldn't have caused the bolt to come loose, and I don' believe the boys at Honda left 'em loose either. k20=timing chain
regardless, it happened. he replaced the cam and rocker assembly and the car started right up. i'm still telling him to do a leakdown to check for bent valves.
I saw something like this on a 97 Mazda Protege' 1.6. A buddy called me to ask if his timing belt should have broken at 81K, yet was due at 105K. He told me a few hours later that the oil LEVEL was good, the timing belt intact, but that the cams actually snapped, because they seized. Turns out he was beyond overdue for that oil change, and topped his oil after being sidelined (to throw his wife off the trail, I figured). Guess he didn't want to live up to being an ***.
That cam in this R- looks fairly worn in some places, (unless it's not a roller) as if something was brewing a while before she gave up the ghost.
You could take what's left of the camshaft to a metallurgist. He or she would probably be able to offer some insight. Seems weird that an OEM camshaft in a basically stock engine would snap.
turbotime
Nov 9, 2005 09:36 PM
NiiS
41
Apr 7, 2003 07:36 PM
