clutch reservoir
My clutch reservoir is leaking somewhere, which is surprising
under the dash where the pedal is it has some black grease, which could be it
how can this be resolved?
Any thoughts?
hope this is the right forum. but yea i had no pressure one time and saw that the fluid was all gone. what fluid should i put in there?
people say that the cylinder is going bad.
but lmk what you guys know of or experience of.
Thanks.
Any thoughts?
Thanks.
Its time to replace the Clutch Master Cylinder!!...the black grease is a sign that it is leaking into your passenger compartment...if you closer around that area you will probaly notice that the carpet/foam in that area will be oil stained
[Modified by 1fastVX, 5:15 PM 10/21/2002]
it happens over time/mileage etc.
It's like a regular master cylinder....they need replacing from time to time
but how much should my clutch reservoir run about? and how about do i go replacing it myself?
thanks for the help
namblagambla
Feb 6, 2013 12:25 PM
