GA FS: EG MIKE's Orange 1992 Honda Civic Hatchback | TypeR | RyWire | Skunk2 | Must See
CAR HAS BEEN SOLD! Thanks for Viewing
Hello world,
I am trying to sell my car due to my financial situation. I am looking to sell the entire car without separating parts.
I bought this car back in 2005 from my friends grandmother. It was originally Harvard Blue Pearl. I decided to go with a full color change when I blew my engine up during an Auto-x event. You can get more details from my Build Thread.
Note: Engine and most parts have around 2,100 miles since rebuild (Everything was Machined and Balanced & resurfaced ITR flywheel) (All new Honda OEM Parts: seals,belts,waterpump,oilpump,etc)
Car: 1992 Honda Civic Dx Hatchback
Engine:
B18c1 w/ Type-R Transmission
ATS 4.9 Final Drive
Integra LS 5th Gear (Cruise at 80mph without vtec engaging)
B16 .02 overbore Pistons
Skunk2 Stage1 Cams
Skunk2 Cam Gears
Skunk2 Intake Manifold
Skunk2 70mm Throttle Body
RC 310 Injectors
RPF Header
ARP Head Bolts
J’s Style Intake
RYWIRE Quick Connect B-Series Engine Harness
Braille Battery (6.6lb)
ChaseBays Charge Harness
DownStarInc Tucked Clutch Line
Bolt Boys B-Series Engine and Fender Kit
Innovative Solid Mounts in anodized black
Exedy Stage 1 Clutch
Type-R Resurfaced Flywheel
Hybrid Racing Oil Cap
Walbro 255 Fuel Pump
CXRacing Dual Core Radiator w/ Slim Fan
Mugen Radiator Cap
P28 ECU Chipped and Tuned on Chrome (Dyno’d at 177whp 120~Torq) - Looking for graph
Suspension / Wheels / Brakes
15x8 949 Racing Rims w/ 215/45/15 Hankook Ventus R-S3
Project Kics Lug Nuts
Koni Yellow Shocks
Ground Control Sleeves with Eibach Custom Springs 450lb front 550lb rear
Ground Control Top Hats
Skunk2 Front Camber Kit
SPC Rear Camber Kit
SPC Rear Toe Kit
ASR Rear SubFrame Brace
Superstar Customs Brake Booster Delete
Wilwood Brake Master Cylinder
Wilwood Brake Proportion Valve
GSR Front and Rear Disc Brakes
GSR Front and Rear Sway Bars
Blox Adjustable Spherical Rear Sway Bar End Links
Exterior & Bay
Full Color Change Inside and Out House of Kolor Firemist Orange
Shaved and Tucked (Brake Lines and Wires)
VIS Carbon Fiber Tail-Gate
VIS Carbon Fiber Duck Bill
PasswordJDM Thin Side Moldings
JDM Headlights
Stanley Amber Corner Lights
Stanley Amber Side Marker Lights
Spoon Style Mirrors
OEM Front Lip
Interior
Recaro Pole Position Racing Seat
Honda Del Sol Passenger Seat wrapped in black tweed (have both seats)
(2) CROW 5-Point Restraints Harnesses
6-Point AutoPower Bolt-in Roll Cage
Fastline Performance Extended Shifter
Spoon Shift ****
Momo Steering Wheel
Momo Hub
NRG Quick Release
Re-wraped front door panels in purple tweed
Price: $7,500
Hello world,
Engine:
ATS 4.9 Final Drive
Skunk2 Stage1 Cams
Skunk2 Cam Gears
RC 310 Injectors
RPF Header
ARP Head Bolts
J’s Style Intake
Mugen Radiator Cap
Koni Yellow Shocks
SPC Rear Camber Kit
SPC Rear Toe Kit
Exterior & Bay
JDM Headlights
Spoon Style Mirrors
OEM Front Lip
Interior
Spoon Shift ****
Momo Steering Wheel
Momo Hub
NRG Quick Release
Price: $7,500
I've followed this build both on here and on Facebook, and finally saw it in person at the Spring 2012 IA meet. It's a crying shame to see someone put so much love into building a car like this and have to sell it due to circumstances.
Bump for a car that's worth every penny.
Could you add a interior shot as it is.
Around 11.5:1cr? Also, what was done on the engine rebuild?
Very close to that compression.
Engine Rebuild and New Parts:
- Bored .02 over with OEM oversized B16 Pistons
- Head slightly milled
- Crank re-finished
- TypeR Flywheel Refinished
- Crank, Crank Pulley, Flywheel balanced
- ACL Race Bearings
- ARP Head Studs
- OEM Piston Rings
- OEM Crank, Cam(2), and Rear Main Seals
- OEM Timing Belt
- OEM TypeR Waterpump
- OEM Oil Pan, Valve Cover Gaskets
really nice car man. Good job.
Is it just the sun or does the drivers door look a diff shade?
PRICE DROP $9,100obo
I am looking to pay off my debt. Please email me if you are interested.
egmik3 @ gmail
egmik3 @ gmail
