How is a D-series Linkage Bar suppose to look on the tranmssion end?
Old Feb 7, 2013 | 11:06 AM
civic4life8045's Avatar
Default How is a D-series Linkage Bar suppose to look on the tranmssion end?
hi HT ..i have a 91 civic d-series... and im looking at my linkage bar from underneath..It looks like its open or gap between the bar and transmssion ...Does anyone know if its suppose to look closed or open???
Old Feb 7, 2013 | 11:13 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: How is a D-series Linkage Bar suppose to look on the tranmssion end?
One bar is on a pivot, the other is attached to a rod that slides in/out and twists. Not sure what you mean by it looks open.
Old Feb 7, 2013 | 11:21 AM
i know one of the bar doesnt move..but the other one when i put it in neutral ..its looks open in other words the rubber part isnt touching the tranmssion... which i think its suppose to
Old Feb 7, 2013 | 11:33 AM
24TEN's Avatar
PHANTOM MENACE
I think that's the actual seal which (please correct me if I'm wrong anyone) should stay in place, flush to the transmission surface. I remember replacing mine when I rebuilt my transmission and it was an extremely tight fit.
Old Feb 7, 2013 | 01:37 PM
grog's Avatar
Yeah if you're refering to the rubber boot it should stay flush with the tranny as 24TEN mentioned. You should be able to push it back into place, there should be a ridge/ lip you'll have to push it over which holds it in place.
Its possible the boot is cracked though and wont go back.
Old Feb 7, 2013 | 02:32 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
that boot gets cooked by the close proximity to the exhaust and exposes the friction pin joint. replace the boot (make sure to replace the friction pin after removing it).
Old Feb 7, 2013 | 08:00 PM
ChokolAwt's Avatar
Originally Posted by Ash J. Williams
(make sure to replace the bitch pin after removing it).
ftfy
K2e2vin
10
Aug 8, 2008 01:33 PM
unsungfate
May 20, 2008 12:07 AM
S2KGirlie
Nov 15, 2003 04:06 PM
nijia555
Jan 1, 2003 03:48 AM
Foozball26
Nov 13, 2002 04:50 PM
