97 Civic Viper 5704
Old Feb 7, 2013 | 08:46 AM
genner's Avatar
Default 97 Civic Viper 5704
Hello All,
I have a question regarding the dome lighte hookup. On a 97 civic with the Viper 5704 alarm.
I've directly tapped the 5704 dome light wire into the Green harness behind the radio dome light wire. However the function to turn on the dome light when the door is open does not work. On position turns on the light but the middle selection for the on when door is open does not work. Please Help.
Thanks!
Old Feb 8, 2013 | 09:44 AM
fcm's Avatar
fcm
Old Fart
Default Re: 97 Civic Viper 5704
Have you installed an aftermarket stereo into the car?
If so, and unless you used a jumper or the T harness and left stock unit in the dash you have opened the dome light circuit...
http://www.installdr.com/InstallDocs...PDF/466013.asp
It's an easy fix. 94
Old Feb 12, 2013 | 09:00 PM
genner's Avatar
Hello FCM,
You are correct, I have an aftermarket stereo installed. The stock deck unit has been completely removed from the vehicle. Although it is not a big deal that the door open dome light on function does not work, I am just wondering what is now needed to make it function correctly again?
Thanks for your help!
Old Feb 13, 2013 | 05:35 AM
fcm's Avatar
fcm
Old Fart
Simple enough, get the Schoche HAK3B harness/adapter, it comes with the jumper for the green keyless entry plug, or just jump the light green/red and light green/black leads in th green plug. 94
Old Feb 19, 2013 | 12:39 PM
GagnarTheUnruly's Avatar
Is this also a problem on Integras?
Old Feb 19, 2013 | 08:05 PM
LongLiveMoon's Avatar
No, just 96-98 civics
Kposey
Mar 3, 2017 05:35 AM
ChrisJavier
Feb 1, 2015 10:47 AM
strangeyelp
Audio / Security / Video
11
Apr 20, 2009 11:10 AM
DelSolDon
Feb 26, 2009 03:42 PM
Civic4less
Mar 28, 2005 08:57 AM
