lsd in d16a6
Old Oct 21, 2002 | 05:45 AM
rexinfection's Avatar
Default lsd in d16a6
How can you tell a tranny is LSD for a d16a6?
Starting to search for a motor and tranny for my current project.
So if I am to get one I figure might as well be LSD.
Old Oct 21, 2002 | 06:41 AM
Louie B.'s Avatar
Default Re: lsd in d16a6 (rexinfection)
The only trannys that came stock with LSDs that fit the d series engines is the ZC trans. you can get a new aftermarket LSD to fit the Si trans, or possibly get extremly lucky and find one someone else did this to. I've been told you can tell if a trans has LSD by pulling both axles out of the tranny case, and look in the hole where they go. If you see daylight from one hole to the other, you're peg-legging. If you can't see through, you've got LSD.
I've heard that the best setup is to get a ZC trans W/ LSD and put the final drive gears from an SI trans into it. that gives you good gearing, LSD, and equal length axles.
Old Oct 21, 2002 | 07:01 AM
crxgurlllll's Avatar
Default Re: lsd in d16a6 (thumpu77)
other way around bud.....
cant see thru no lsd
see thru.... LSD
Old Oct 21, 2002 | 08:16 AM
If I go ZC trans with LSD, do I have to get the axles as well?
Old Oct 21, 2002 | 08:25 AM
keithv's Avatar
you can use 90-93 teg axles with the ZC trans. the ZC trans also uses an intermediate shaft which can be sourced from a number of hondas (i don't remember which exact ones, so i won't say).
Old Oct 21, 2002 | 01:16 PM
Louie B.'s Avatar
Default Re: lsd in d16a6 (eraser)
see thru.... LSD
Cool, that means the 88 Si "A000" tranny I have has LSD!!!!
Sorry for the mis-info
johngrady
Jan 28, 2008 01:29 PM
DmcL
Jan 20, 2007 06:22 AM
tcc1577
10
Sep 6, 2004 07:26 PM
juiceman
Jul 15, 2002 05:30 AM
