Need info wiring 91 crx
I have a 1991 crx base model with a DOHC ZC swap. I have searched and searched for all the info I can find to re-wire it. I read that to re-wire it I have to get the stock DPFI harness and swap it to MPFI. Is there a reason I couldn't get a HF or Si engine harness? I found someone with a wrecked 91 crx si for a good price and I'm hoping to use it as a parts car because I need more than just an engine harness.. but for now the wiring is my main concern. it runs but it doesn't run all that well..
Edit: NVM Sorry lol misread your post. :/
There are no CRXs that are OBD1 from the factory in the States.
Your engine harness must match your chassis harness so if you are getting the Si CRX then you could use the chassis harness from it as well as the engine harness but it is quite a lot of work to change it all over.
Crx_Daniel
Feb 6, 2013 01:01 PM
Forgotten4door
Jul 26, 2009 01:00 PM
OMG PLEASE HELP!! 91 CRX SI OR HFENGINE WIRING HARNESS DOES ANYONE HAVE ONE. THIS IS JUST FUCKING ST
Markb16a
Jan 1, 2006 12:53 PM
crxb18a1
24
Aug 14, 2004 05:39 PM
