Sunroof and rust?
Old Feb 6, 2013 | 10:23 AM
AddiXz's Avatar
Default Sunroof and rust?
So i have 2 little things i need to fix.
1. is my sunroof is leaking. What could be the problems? I want to check if there are any other options before replacing the rubber first.
2. I have some rust (well known honda places). Wich are through at both side's. Is it better to weld in some pieces of sheet metal, or would it be a better idea to just replace the panels or parts of the panels?
Thanks in advance
Old Feb 7, 2013 | 03:07 AM
AddiXz's Avatar
Default Re: Sunroof and rust?
*bump*
Old Apr 14, 2013 | 12:00 PM
AddiXz's Avatar
Small bump. Been thinking about using fiberglass to fix the rust spots. Any ideas on this and if this will work?
grumblemarc's Avatar
The Grumpiest
Replace metal with metal.
Old Apr 14, 2013 | 12:02 PM
AddiXz's Avatar
So fiberglass is not an option? Should i weld in complete parts, or could i just use some sheet metal to fix it?
The Grumpiest
That's up to you.
Old Apr 14, 2013 | 12:15 PM
AddiXz's Avatar
Ok, any ideas about the sunroof?
bluenc-87
Paint and Body
Jun 21, 2009 05:17 PM
taking-back-sunday07
Apr 7, 2007 06:40 AM
silver5spd
Apr 8, 2005 11:56 AM
JonGP4
Oct 19, 2003 04:34 PM
Nader_D
Jul 23, 2003 08:43 PM
