OMNI MBX compatibility ?
I purchased a glallon of omni mbx 3.5 voc candy apple red paint. The mix ration is 1:1 with no hardener. im not sure what reducer to mix with. I was gonna take it to the local paint store and see what they say.
I also am not sure of what clear coat to use. PPG website says use compatible omni clear coat. I was planning to use diamond clear from the local store.
anyone familiar with this paint?
I am, Omni is a ok brand... It is mixed 1:1 with Med. Reducer or fast or slow depending on temps when you paint.
Go here: https://buyat.ppg.com/refinishProductCatalog/
That will take you to the product pages for there materials, tell you how you need to sand and prep you car for base, clear. Deltron is what we use in the shop and it does awsome, and flows together very nice and is easy to cut and buff.
I'm going to see what the local shop says
There are some products that are not compatiable tho so make sure to ask. It could cause lifting or maping or mottling if they are not compatible. You can get Shop line or Omni Clear as an entry level clear. If you want a good clear get Deltron 3000 it will look like glass when your done, very little cut and buff or any would be needed. It runs about 295 for a gal of clear and a gal of hardner. Shop line is pretty cheap but dosent last as long if in day light alot.
Look for Shopline or Omni clear coat (dont remember the offical name)Remember the more exspensive clears will lay down flater, so less wet sanding will be needed. Shop line and omni are pretty much the same thing too so get whatever is cheapest, they are both PPG.
if its your first time spraying, you dont need a top of the line clear, you dont know how to spray in order to lay it on like its designed too. buy a cheaper clear, like 3or more coats on there not to to wet, and then just cut and buff to perfection man. play it safe, learn the ropes, spray a lot of panels before you go exploring top of the line materials if your just getting into it
thanks for all the advice. i found a local supplier tha carries ppg products and got what i needed. i went with the shopline clear for 80 bucks.
do i need some flex add for the plastic exterior parts? should i add it to primer, base, clear or all three?
i got some autobahn adhesive promotor in a can. i was gonna spray it befor primer sealer, i do have a few small spots where there is bare plastic. i sanded everything down with 180 , and im putting two layers of primer sealer.
