95 DPFI D15b2: Why do a DPFI to MPFI swap?
So.. I had to bring my old D13b2 EG3 to the scrapyard and bought me a newer '95 DPFI D15b2. Now i've been thinking about swapping the DPFI to MPFI. But i'm actually wondering what the pro's and con's are.
So here are my questions:
1. What are the pro's of a DPFI->MPFI swap?
2. Are there any con's (apart from time and money it takes)?
3. Why were there different (DPFI and MPFI) models?
4. Does it really help me to get MPFI?
5. What kind of power gain do i get out of a MPFI swap?
Also i have to replace the head gasket. So i have to take the engine apart for a good maintenance anyway. i have some questions about this as well:
1. What parts should i check while replacing the head gasket?
2. I don't have the manual. Can anyone give me the torque settings for putting the head back on?
3. Would it be a good idea to do a mini-me when i allready have the head off?
4. If so, what would be the best head if i'd do a mini-me?
So those are my questions for now. Thanks in advance!
Last edited by AddiXz; Feb 6, 2013 at 10:21 AM. Reason: Moderator gave me some handy advice! :P
I understand. The questions you are asking just happen to be a better fit for members who frequent this forum due to differences between USDM and EDM Civics.
Mpfi has better throttle response and more power (a gain of >15hp isn't unheard of) so a LARGE difference.
For a minime sway you have to have DPFI. D16z6 is a good head.
If you do a DPFI swap you need a new Disi fyi.
Also you can tune a MPFI set up.
The DPFI setup is great for the gas mileage though.
You can get awesome fuel mileage out of either one, but being that the DPFI is SO GUTTLESS its a little easier to get milage.
While the engine is apart, new timing belt and water pump.
For all that work you could just grab a full Z6 with ecu and harness and call it a day..
The mileage is'nt my biggest priority. Most things that i have to go to are within 50km from my home. So i think i'd drive about 750-800km max a week. pumping gas in her 2x a week is'nt such a big deal atm.
I would have to have a DPFI for a mini-me? o.O I thought it'd be the other way around.. i thought i'd need a MPFI for a mini-me..
btw.. Disi? Sorry, i'm dutch. Don't know that term.
He meant to say you have to go mpfi for the mini-me swap. and disi is short for distributor. You will need the one that matches the ecu you will be using. http://hondaswap.com/swap-articles/d...writeup-49557/
At my local scrapyard there is a '98 EK hatch with a 1.5 MPFI engine in it. They would sell me the MPFI system for a 100 euro's. Would this be a good idea? Cause i've been reading up a little and all i see is about the 88-91 systems.
Also does anyone have any answers to my other questions? Thanks
It would be fine if you posted your questions below as a separate thread in the 92-00 Civic forum.
Also i have 2 little things i need to fix.
1. is my sunroof is leaking. What could be the problems? I want to check if there are any other options before replacing the rubber first.
2. I have some rust (well known honda places). Wich are through at both side's. Is it better to weld in some pieces of sheet metal, or would it be a better idea to just replace the panels or parts of the panels?
1. What are the pro's of a DPFI->MPFI swap?A lot more power
2. Are there any con's (apart from time and money it takes)? less gas milage
3. Why were there different (DPFI and MPFI) models?i have no idea why DPFI ever existed. the HF CRX was MPFI and got ungodly MPG
4. Does it really help me to get MPFI? yes
5. What kind of power gain do i get out of a MPFI swap? 10-15 REAL HP. not like a 10hp exhaust system that actually gives you 6.
1. What parts should i check while replacing the head gasket? use a straight edge to make sure the head and block are still flat. while you have it apart, replace timing belt, water pump, and timing tentioner. oil pump is also a good idea.
2. I don't have the manual. Can anyone give me the torque settings for putting the head back on? Google.com
3. Would it be a good idea to do a mini-me when i allready have the head off? You can, I did. The mini me will give you about 130hp. you have to get a new ECU, Convert to OBD1 (if you arent already) run extra wires, and get a new distributor. in my opinion this is the best thing you can do to these cars $ to HP wise.
4. If so, what would be the best head if i'd do a mini-me?I'd go with a Z6 head, y8 intake manifold.
Only possible con is if you use the car strictly as a point A to point B commuter car (even that's subjective). Possibly be better to leave it alone and just enjoy an unmolested engine/car.
Difference in design/purpose. Evolution. Revolution. Take a pick.
Depends on what you want to do with your car. The only difference as a negative is that you might have slightly less MPGs. It's a small trade off for what you gain in acceleration and overall drive-ability.
Depends on the overall condition of your engine. As long as you're realistic about your expectations about the upgrade you will be pleased with the difference in power.
Once again subjective. Pros/cons to any head swap.
One thing to keep in mind is if you are going to do any kind of serious upgrading and/or engine swap, a MPFI is almost literally a must. It's better to get it converted on an engine that you know runs as opposed to swapping an engine AND completing a MPFI conversion in one shot.
Now these are some handy answers. Get's me alot closer to the knowledge i'd like to have about this subject. I thank you guys alot and if there are more opinions. Other people can still give me those.
If i read this right, a mini-me would be quite a good idea on my current plans right?
What about the all-round costs?
What parts do i need to do the z6 mini-me?
thanks!
thanks!
AddiXz- I f you get this. i did an mpfi swap last summer, had most same questions as you. It is a daily driver from school to work and of course cruising.
I had i want to say about 10 extra horses to it, before i got headers and intake. however i do highly recommend those once you complete the swap that another easy 10 horses or so. Have it tuned correctly by a mechanic, dont redline it constantly or you'll wear out your rings real quick like i did.
In parts and everything not including the manifold,ecu,and distributor, about $200+
If you decide to do so, it is a great learning experience if you do it right, if you don't do it right you want to get rid of that thing real quick itll **** you off beyond limits.
For parts:
-OBD0-OBD1 conversion from rywire and optional VTEC
-4 wire o2 sensor
-all upper gaskets real street perfromance had a kit for around 160? it has every litle gasket you need
-OBD1 dist.
-P28 or P08 ecu
-lots of extra wire
-you'll need round MPFI dizzy plug for the conversion along with the injector plugs
-basic sh*t like coolant and oil and filter might as well change it
and all that is for a Z6 conversion. Good Luck!
You only need half of this if you just plan on changing the manifold doing a normal MPFI swap
For parts:
-4 wire o2 sensor
-OBD1 dist.
-P28 or P08 ecu
-lots of extra wire
For parts:
-4 wire o2 sensor
-OBD1 dist.
-P28 or P08 ecu
-lots of extra wire
For parts:
-4 wire o2 sensor
-OBD1 dist.
-P28 or P08 ecu
-lots of extra wire
zapzach
May 7, 2013 09:39 AM
turn&burn89
Mar 29, 2013 06:56 AM
