88-91 civic VSS question
Old Feb 6, 2013 | 04:49 AM
crxguy406's Avatar
Default 88-91 civic VSS question
My particular vehicle: 90 crx dx, (manual)
I've been shopping around for universal cruise control kits, and I found one I like. Unlike other cruise control kits I've seen which use a speedometer cable pickup or a tachometer pickup, this one says it "uses a VSS (Vehicle Speed Sensor) wire from your engine compartment."
Is the VSS just another word for the speedo cable? or is there something else on these cars which this kit may be referring to? I just want to be sure this kit will work before actually buying it.
Old Feb 6, 2013 | 05:38 AM
Former User's Avatar
Default Re: 88-91 civic VSS question
In this case, you would probably get the speed pulser/VSS signal by tapping into the Yel/Red wire that runs between the speedometer and the ECU.
Old Feb 6, 2013 | 06:13 AM
crxguy406's Avatar
ohhh thanks! I'd forgotten all about that wire.
Zewle
Aug 8, 2007 07:09 PM
uncle L
Jul 26, 2007 08:29 PM
yellowjdmcrx
Nov 22, 2005 08:05 AM
rice4life
May 14, 2002 07:24 PM
rice4life
May 14, 2002 12:27 AM
