Jumper Wire Kits
I am going to be testing the connector going to the FSU in my 93 Accord LX and the service manual states the use of jumper wires to ground. Where can I get a kit of these to use for future applications as well?
Thank You!
Thank You!
Fuel sensing unit, sorry.
What about flat pin leads (female and male), jumper wires, just so I can connect into the connector and walk away to turn the ignition key.
I need something that will hold onto the flat pins too. I can insert wires into the female connector but for the male connectors I need leads that will hold to the flat pin.
Ahhh - if you mean the flat connectors that I think you do, you could use spade connectors. If you're feeling adventurous you could crimp a wire in across two of those and use it as a jumper as well.
yes, exactly. Where do I find the size I will need for the application? I would think radioshack would carry an assortment. It seems the ones we have on all the connectors are 3-4mm at most in width.
I've always picked up the assorted packs at Lowes/Home Depot with good luck. Most auto stores should have them as well. Smaller than that you would probably need Radioshack or another electronics store.
.water
Audio / Security / Video
24
Dec 18, 2005 12:23 AM
