Transmission & Drivetrain Gearboxes, Differentials, Clutches
89 b16 lsd & diff into 93 ys1 case?
Old Feb 5, 2013 | 11:29 PM
crxcess's Avatar
Icon6 89 b16 lsd & diff into 93 ys1 case?
I have a couple of b-transmissions that I want to mix and match internals
1. 89 b16 trans with a factory lsd - 3rd gear is toast
2. 93 ys1 gsr trans - broken diff
will the diff with lsd from the 89 b16 trans fit in the 93 ys1 case?
I also have a 91 ys1 teg LS trans, if the lsd diff doesn't fit in the ysi case, can I at least put the lsd onto the LS diff, then I know that will fit in the gsr case.
Old Feb 9, 2013 | 06:53 PM
KIWI's Avatar
Default Re: 89 b16 lsd & diff into 93 ys1 case?
If your '89 B16 Box is a S1 or a Y1 Then nothing will interchange with your YS1
If the Ring Gear on your '89 B16 LSD Has more than 10 bolt holes It won't fit anything else either, as far as I know?
The early Y1 and S1 Boxes had 12 bolt holes on the Ring gear.
Kiwi
clinicallyill
Sep 9, 2011 06:17 AM
Ti3d in
Mar 16, 2009 02:46 PM
Rikter
Oct 10, 2006 06:10 PM
hondatuner123
May 16, 2006 08:16 PM
ZenDynasty
Mar 27, 2005 09:19 PM
