NV 97 Prelude Built ( 5th GEN )
I unfortunately have to give up my baby. she's a 1997 Prelude with approx 210k mi on the chassis. Car needs a re-spray on the paint due to vandalism however the rest of the car is in nice shape. It currently is not running only needs a Head gasket and possibly a upgraded water pump. the motor as it sits now is as listed :
2K H22a4 block Darton MID 89mm bore, decked, honed, line honed, etc. 89mm bore JE pistons 9:1 Total Seal gapless rings Carillo H beam Rods Factory Bearings/seals/gaskets Circuit works/pro-drive oil pump gear Cometic HP gasket ARP Main Studs
Main clearances .0021, rods .0017, .0045 piston to wall, torqued rods 28ft lbs, mains 65 ft lbs...etc
Motor was installed by LDL motorsports here in Las Vegas, NV have all receipts for work done. Car will come with stock rims unless you would also like to purchase my 18'' 5Zigen proracer GN +. Car currently has front & rear DC Struts, VAFC 2, TEIN Springs, Port matched & polished Head with titanium valves, springs etc ... 3 in full custom exhaust. there are some other mods that i cannot remember right now. price for the car is $3500 or $4100 with the rims. any interest LMK
picture are here http://www.flickr.com/photos/djcasanovar32/
Saltine Box Racer
Apr 14, 2003 12:15 PM
