Where is crankshaft position sensor located 01 CRV
Where is it in this bernardi parts diagram?
http://www.bernardiparts.com/SearchO...onda-crv-parts
Is there a sensor that attaches to the engine?
2001 crv lx 4wd
2001 crv lx 4wd
sorry i thought you said cam sensor. if i remember correctly, its on the top/rear of the crank pully, under the water pump. might be able to get it from the wheel well.
youve gotta pull off the pully to get to it. Youre going that far, you should change your timing belt and water pump while youre there if you havent already.
canuck2
Honda Civic (2001 - 2005)
Jul 31, 2019 05:12 PM
