After instilling MSD 6AL, Car misfire at 4500RMP and up
Car was running fine no problem, stock dizzy, FPR at 55-60,tuned ECU.
Right after i slaped on the MSD 6AL, car fired up cool. and took it for a spin and the car would move but at high RPM the car BOOGS.. sounds like a misfire or lack or fuel! nunthing has change after i install the MSD.
MY SETUP
85x89
wesco 13.2.1 CR
b16 head Spuertech Every thing
Sunk2Pro2
RC310
NGK iradium X, didnt check the gap but i think its 30+? somewhere near there.
FPR at 60 after the misfire changed it to 40 to see if it would help, NOPE
VictorX IntakeManifold
70MM TB
Dizzy is Retard
stock sparkplugs wires...
Question is i know i didnt do anything wrong but does the MSD require more of somthing since its be install? or should i Re-Gap the spark plugs to somewhere around 18-20-25?
advance the dizzy? try diffrent sparkplugs wires?
Give me your advise or experinces...
MY SETUP
85x89
wesco 13.2.1 CR
Sunk2Pro2
RC310
70MM TB
Dizzy is Retard
what happen was the spark plugs went out! but how? they where NEW!???? No more then 100 miles on them! what could of caused this? were they going bad? i put the stock dizzy back on and it still sputter at HIGH RMP so i decided to try diffrent wires and still same thing, so got new spark plugs and bamm! it worked,... is the MSD bad? or were the spark plugs? and should i try to set it up agian?
also can it be because of the heat range? the plugs didnt melt but im clueless to why they went out?
ProjectEvilEj2
Feb 6, 2013 05:08 AM
LshatchTurbo
Jan 15, 2002 07:53 PM
