Transmission & Drivetrain Gearboxes, Differentials, Clutches
innovative mounts hydro to cable conversion kit wright up
Old Feb 5, 2013 | 12:45 AM
1320king's Avatar
Default innovative mounts hydro to cable conversion kit wright up
hey thought i will do a quick review and wright up on the innovative hydro to cable conversion kit to install a cable trans in a hydro civic. Reason why i did this was i had a ys1 cable trans case with type r gears with 4.4 fd, carbon syncros, and mfactory lsd built from syncrotech for my crx before i sold it so i didnt want to sell a good working trans with the exact gears i wanted, so i looked in to a conversion kit. Couldnt find good pictures or much info on this kit, if i missed anything let me know so i can edit. Here we go.
First off this is the kit it self i already mounted one of the brackets you can see its the nice black bracket bolted to the trans. What it comes with is motor mount bracket, the bracket for the clutch slave and the rod end for the slave.
Second you will drill a 5/16" hole on the clutch arm, the position of the hole is 2.5" from the center of the shaft that is welded to the arm. note its easiest to drill with the trans out of the car.
Third you can bolt the rod end to the arm
Fourth now you can install the trans with the new motor mount bracket in car. Now bolt the slave to the bracket bolted below the clutch arm. note the kit dose not come with bolts to bolt the slave to the bracket, well mine did not.
and thats about it. The kit worked very well pleased with results how the car drives and shifts, cant even tell its a cable trans in a 97 civic. So any other questions on the install i can help out the best i can just pm me. Thanks.
Old Feb 20, 2013 | 09:51 PM
kelzyrenee's Avatar
Default Re: innovative mounts hydro to cable conversion kit wright up
THANK YOU! Seriously. I have been looking for good info with pictures on this for weeks now. I'm putting my b18a in my del sol and was considering this kit. Now that I know how it works, I will be getting it. THANK YOU SO SO SO MUCH!
That VTec Guy
Aug 13, 2012 03:48 PM
ben.batiste
Nov 30, 2009 12:32 AM
92EGminihatch
Jul 3, 2009 11:48 AM
ToKeNbLcKgUy
Aug 11, 2005 02:10 PM
nousername
Jun 29, 2004 09:53 AM
