Coolant leak
Old Feb 4, 2013 | 02:07 PM
JuneBugDrfter's Avatar
Default Coolant leak
My EF has a major water leak near water pump. The water pump is running fine. No leaks in timing belt area. The water pump pipe isnt leaking either. I'm thinking A BHG. but no coolant in the oil. I had a B16 twin cam engine in it with a bhg when i bought it. I did a D15 swap and D16 SI transmission. IDK what would cause major water leak near water pump. ??????
Old Feb 4, 2013 | 02:54 PM
grog's Avatar
Default Re: Coolant leak
I had a leak under my intake near the water pump a while back. It was coming from the big coolant pipe that runs from one side to the other. This pipe has O-rings on each end, one of them went bad. But I replaced both while I had the pipe out.
This coolant pipe is also called a "water pump inlet pipe".
Dry everything off real good then have somebody start it while you observe where its coming from.
Also is this coming out of the weep hole on the water pump?
Old Feb 4, 2013 | 02:55 PM
EfyourK's Avatar
Water leak near water pump... Bad/ incorrect gasket.
Old Feb 4, 2013 | 05:38 PM
I did a dawn dishsoap test and its shooting at high pressure out top weep hole near water pump. but dripping fast under the water pump with engine off as i fill up radiator. Will a 2.2L raditor caused the water pump to fail?
Old Feb 4, 2013 | 06:11 PM
grog's Avatar
Its likely your water pump is on the way out, you can read up on it here: http://www.flowkoolerwaterpumps.com/..._failures.html
The capacity of your radiator has no effect on the pump and its seals.
Old Feb 5, 2013 | 07:18 PM
Jockone's Avatar
Sounds like the seal on the shaft of the waterpump is bad if it is leaking out the weep hole.
Time to replace the pump.
Old Feb 5, 2013 | 08:57 PM
Former User's Avatar
Originally Posted by Jockone
Sounds like...waterpump is...leaking out the weep hole.
This^
accord1986
Jan 27, 2013 03:01 AM
niceprelude
Feb 15, 2009 10:20 PM
jpelle
Jan 13, 2007 05:55 PM
tominos
Sep 10, 2004 08:38 PM
