96 Civic DX difficult to start after replacing head gasket - please help!
Well i changed my head gasket and then had a vacuum leak but i found it and now it has problems turning on, it take a good 5 seconds and with help with pressing the gas to turn on.Any advice??
check you valve lash,fitv,iacv an ur tps
check ur tps n see if its at .5 volts an nut under
check ur fitv clean it an see if the white thing inside is screwed all the way in
when its running where does ur idle sit at cold and warm?
raider1qaz
Feb 1, 2013 12:44 PM
i love turbo honda
Nov 11, 2008 02:50 PM
efprojectboost
Jan 1, 2008 02:12 PM
