Going up in Tire Size
Old Feb 4, 2013 | 06:45 AM
goad's Avatar
Default Going up in Tire Size
Have Honda Accord LX.
OE Tire size is P195/65-R15
Can I go to P205/75-R15??
Have a junk Lumina and want to exchange tires.
Thanks
Ken
Old Feb 4, 2013 | 07:17 AM
92 civic ex 4dr's Avatar
Default Re: Going up in Tire Size
you can yes. You might have rubbing issues when turning and compressing the suspension.
Old Feb 4, 2013 | 07:19 AM
goad's Avatar
Thanks....I suppose that the wheels from the lumina will not fit the hub on the Honda?
Old Feb 4, 2013 | 07:21 AM
that depends. If the Lumina is 4 1/2" lug pattern then yes. if its 4" or five lug then no. It never hurts to try. worst to happen is it wont fit.
Old Feb 4, 2013 | 07:23 AM
goad's Avatar
Ok....I appreciate your help. I didnt try. I will do that.
Old Feb 4, 2013 | 07:27 AM
Just an FYI. Next time you post something, espectially if it's more technical, please include the year of the car as well. Some people around here will chew you out for not posting it. The year makes a difference.
Old Feb 4, 2013 | 08:00 AM
goad's Avatar
My apology...I thought I had. It is a 2001.
Old Feb 4, 2013 | 08:04 AM
I don't know much past the fourth and fifth gen accords. Never worked on anything older than a 90 or newer than a 97. So im not sure what the lug pattern is on that year/model.
Old Feb 4, 2013 | 08:28 AM
goad's Avatar
Well unfortunately I wont be able to actually check it all out until this weekend to see if the lug patterns are the same or not....
Old Feb 4, 2013 | 09:23 AM
TheMuffinMan's Avatar
He knows where you live!
90-02 4-lug Accords are 4x114.3
98-02 5-lug Accords are 5x114.3
All the Chevy Luminas I can find are 5-lug and are 5x115
Old Feb 4, 2013 | 09:33 AM
MAD_MIKE's Avatar
MM Gruppe B
Thanks
Ken
That's going to be a bit of a leap in diameter size. From 24.9" to 25.9".
This will affect handling, braking, acceleration and your speedometer will be off.
Importn2oRacer
Jun 7, 2007 03:31 AM
Rob Dizzle
Oct 23, 2003 07:35 AM
Shmeek
23
Apr 11, 2003 10:02 AM
CunninLynguist
Feb 7, 2003 04:49 PM
RAB
Aug 9, 2002 01:16 PM
