1994 Honda Accord EX A/T Turned the Ignition On and just Died?
Old Feb 4, 2013 | 05:09 AM
faran's Avatar
Default 1994 Honda Accord EX A/T Turned the Ignition On and just Died?
Techs-
Today in the morning, I turned the ignition on and was about to crank the car and it just died.
Everything disappeared, no turn signal, no lights, no radio, no power locks or windows, seems like a battery problem or a fuse or maybe something else?
Any help or advise would be greatly appreciated
Old Feb 4, 2013 | 05:36 AM
92 civic ex 4dr's Avatar
Default Re: 1994 Honda Accord EX A/T Turned the Ignition On and just Died?
sounds like you need to check/clean all of your grounds. Happened to me too. I guarantee if you "wiggle" the ground attaching to the battery it will all come back on.
Old Feb 4, 2013 | 05:41 AM
faran's Avatar
Ground connected to the "-(Negative)" terminal?
Old Feb 4, 2013 | 06:04 AM
yes. Ground, Negative. same thing.
Old Feb 4, 2013 | 06:06 AM
Its supposed to be black. has the "-" symbol not the "+" symbol. Not trying to be a dick.. you would be surprised how many people i know and have watched hook up jumper cables AND battery terminals backwards..
Old Feb 4, 2013 | 07:54 AM
faran's Avatar
Completely understand and thanks for the heads up
Old Feb 5, 2013 | 04:01 AM
faran's Avatar
Thanks for the advice and help.
It does not seem like a ground issue, because I tried today in the morning, lights do come on and radio/cd player also work if the Switch is at position 'I', if I move to 'II', everything disappears, another weird thing, when I turned the key in Ignition for the first time, everything was good till 'II', as soon as I tried to crank and put to 'III', car just dies and all the lights on the dash disappear too.
Do you think it's the ignition switch or any fuse/relay is blown?
Is there any preference, if I have to buy ignition switch or ebay/used is fine too?
Looking and waiting for some help
Old Feb 5, 2013 | 05:10 AM
A bad ground does that too. I had that problem for a while. It works with a really light charge, but when you turn the ignition and the starter pulls it's draw, it arcs out and makes for a "dirty" or "burned" connection.
Posted from Honda-tech.com App for Android
Old Feb 5, 2013 | 08:03 AM
cctgene's Avatar
One simple thing you can do is just connect one side of a jumper cable to the negative
post and the other end to any place on the engine block. If it will now start then you know your dealing with a ground issue.
Old Feb 6, 2013 | 05:52 AM
faran's Avatar
There is ONLY one thing I can say about you, "YOU SIMPLY ROCK"
Thanks so much for your help and advice.
Actually , ground cable on the battery was lose, used a cleaner, some sandpaper, tighten it up and 'Honey' fired right up(Maybe 5-10 min job)
Thanks a ton for all of your help
Old Feb 6, 2013 | 06:07 AM
Not a problem man. That's what were all here for. Chances are we all have had some kind of problem that somebody else is currently having. Glad i could help.
Mikerugg
Nov 29, 2018 11:41 AM
TeeBoneEX
Dec 27, 2017 12:08 PM
Sean-45
Oct 6, 2017 08:37 PM
bump2pass
Apr 4, 2016 07:29 AM
1999 honda Accord Cali
Jun 17, 2008 06:18 PM
