91 ef hatch dx auto to manual with b16 swap
A lot. Hydro or cable? obd0 or 1?
-manual
transmission
ECU
Shifter/linkage
master cylinder
Slave Cylinder
manual transmission speed sensor
starter
Axles
clutch pedal assembly
Flywheel
transmission motor mount Rear and Left
clutch
-manual
transmission
ECU
Shifter/linkage
master cylinder
Slave Cylinder
starter
Axles
Flywheel
clutch
Read this:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/detailed-b-series-into-crx-ef-civic-parts-list-more-2769325/
And search for something on auto to manual conversion.
1: Convert car to manual - pedal assemblies and what not
2: Do the wiring - DPFI to MPFI and then to OBD1
3: Drop the B16 in
There are TONS of write ups on each of these steps.
Good luck
3: Drop the B16 in
Good luck
E-mac
Feb 11, 2013 02:08 AM
danwants2btheman
Sep 13, 2006 12:33 PM
95civicferio
Nov 12, 2004 08:21 PM
95civicferio
Nov 11, 2004 08:49 PM
