Smog re-test failed. How to fix?
Old Feb 2, 2013 | 04:38 PM
braass91's Avatar
Default Smog re-test failed. How to fix?
1991 Civic DX Hatchback
I took my 91 Civic DX Hatchback for a re-test today and it failed due to:
Visible blue smoke during Snap Test
Timing spec is 18 but reading at 14
Please, let me know how to fix to pass. Thanks
This is the result of my first test, but have replaced the cracked hose.
Smog barely passed emissions but failed due to a vacuum line crack from visual inspection. The NO (PPM) and HC (PPM) barely passed at:
15 mph
NO (PPM) at 834 with max allowed of 835
HC (PPM) at 74 with max allowed of 91
25 mph
NO (PPM) at 605 with maximum allowed of 774
I have replaced the cracked vacuum line and want to do a re-test to pass. My question is, given the high readings above, is it better to do the re-test first thing in the morning or when the engine is hot, or does it matter? The first smog readings above was done first thing in the morning and the engine was still cold. Thanks
666JTK666
Jan 31, 2016 03:49 PM
braass91
11
Nov 26, 2012 06:47 PM
langjairicer
May 28, 2010 01:13 AM
oneforce
Mar 6, 2006 03:13 PM
dcvt16
Apr 24, 2004 10:05 AM
