Need help with Power Steering!
Old Feb 2, 2013 | 01:51 PM
redvelvetsi's Avatar
Default Need help with Power Steering!
My buddy and I pulled a DC2 ps rack from the junkyard but accidentally cut some lines we weren't supposed to, oops! Anyway, I tried to find the OEM replacement part from Acura but that part has been discontinued. Can some one explain what these lines do opposed to the civic rack which doesn't have them? And also, can I just plug them up with a bolt or do I have to have these lines connected?
Item number 21 and 22.
Old Feb 3, 2013 | 03:59 AM
Default Re: Need help with Power Steering!
No one knows? Need to get this thing fixed soon, bad oil pan leak. Want to do it all at the same time.
Old Feb 3, 2013 | 05:19 AM
IN VTEC's Avatar
Do you want power steering?
Old Feb 3, 2013 | 05:42 AM
Yeah, I want to make my nrg quick release last as long as possible. I've thought about a manual rack but not really sure if I want it.
I don't know if you know but 21and 22 go into 17 and then two lines from 17 go up to the pump/reservoir. Picture looks misleading. Thanks.
Old Feb 3, 2013 | 05:50 AM
cvcrcr99's Avatar
What does converting to non P/S have anything to do with a QR?
Do you have a picture of what you cut? Are you looking for #21 and #22?
Old Feb 3, 2013 | 05:53 AM
IN VTEC's Avatar
That's correct. There should be 4 ports on the valve body. Two go to the rack and the other two are in and out to/from the pump.
http://www.redpepperracing.com/techn...7/aas.png.html
http://www.redpepperracing.com/techn...7/aah.png.html
Old Feb 3, 2013 | 05:56 AM
fcm's Avatar
fcm
Old Fart
They are the transfer lines and no, you can not cap them if you want power steering.
Any brake shop can make up a set for you. 94
Old Feb 3, 2013 | 06:01 AM
If I put a manual rack, it'll wear out the ball bearings in the quick release faster won't it? Theoretically anyway.
I don't have a picture but essentially just cut 21 and 22 in half. Buddy went crazy with the cutting pliers trying to get it out, lol.
kirkland08
Jan 25, 2011 10:43 AM
1993gsrcivic
Feb 8, 2009 07:20 AM
nfereorhatch
Jan 14, 2008 10:07 AM
hondime9396
Nov 21, 2004 09:46 PM
