What Could be Wrong?
Old Feb 2, 2013 | 08:02 AM
ChrizXx's Avatar
Icon2 What Could be Wrong?
First I will tell you what i have in my car. (98' Honda Civic EK Coupe - Manual)
B16A2 - 50,000+ Miles
Aftermarket Exhaust
Aftermarket Short-Ram Intake
LCD Transmission
PROBLEM:
For some reason RANDOMLY while shifting or even idleing the RPM will idle at like 2,000 (2) when its suppose to be idleling a little under or over 1.
BUT now when shifting (WHILE THE RMP IS AT 2) not only does it catch the gears late even tho im shifting perfectly, if im on gear and i get off the gas a bit when im already completely off the clutch the car like jumps its like its fighting with me Its a pain.
It seems catch the gears easier if im shifting at HIGH RPM's. Its almost forcing me to only go fast. SORRY its hard to. explain.
DOES ANYONE KNOW WHATS HAPPENING?
PLEASE & THANKS.
Old Feb 2, 2013 | 08:39 AM
grumblemarc's Avatar
The Grumpiest
Default Re: What Could be Wrong?
Er. What?
Old Feb 2, 2013 | 09:52 AM
ChrizXx's Avatar
????? well?
Old Feb 2, 2013 | 09:57 AM
doood's Avatar
been there done that
no idea what you just said
Old Feb 2, 2013 | 10:05 AM
ChrizXx's Avatar
IVE MADE IT MORE CLEAR SORRY PLEASE READ AGAIN HOPE IT HELPS.
Old Feb 2, 2013 | 10:21 AM
cryptonik's Avatar
Generally speaking, if the transmission is hard to shift (no matter the RPM) then you may be looking at a clutch replacement. Not terribly difficult and only takes a handful of tools to get the job done. As for your high idle condition, you could be running into an issue with your Throttle Position Sensor (TPS). You could, however, use the feature of these forums to search on how to fix a high idle.
Old Feb 2, 2013 | 10:32 AM
ChrizXx's Avatar
Thanks man! i actually just loosened the Throttle Wire it was kinda tight hopefully that helps ima look into a clutch cause i do have Stage 1 clutch on a b16 -_- not good i know but ok also ill look into the TPS thank you.
ChrizXx
Feb 17, 2013 10:28 AM
paintb91
Apr 15, 2012 09:48 AM
goern-R
Aug 31, 2003 08:04 PM
p0pe
Mar 14, 2002 09:23 PM
1fastGSR
Jan 29, 2002 01:36 PM
