Help, ITR Type R Integra HID headlights Grey Connector
Cleaning up my HID type R headlights and after doing research and research on how to wire them i take them out and realize i'm still not ready
Looking at my Lights the HID brown cable i noticed the wire between the HID were cut in half on both headlights , but the one going into the brown clip is white and the other is black
then i noticed a plug from the HID ballast with a red and black cable
i found a picture of an HID headlight on Ebay and there is an additional cable that plugs to the Ballast that i did not get
Where can i Locate the Female Plug that goes into the Ballast? Im guessing i can just put some splice connectors but i would prefer to use the gray plug insted
thanks
thanks
well after doing some late night friday night research , i realized why i had those HID headlights stored away for over 5 years..
My 1995 GSR with the Big ABS will not except the HID headlights without either deleting the ABS and making it NON-ABS or converting the headlights from OEM honda to aftermarket Ballast (thinking of maybe going this way for now)
question is, if i do decide to remove the stock Honda Ballast and replacing them with aftermarket , how would i go about covering the round hole that would be open from the missing box ballast ? anyone ever converted them before? how did you go about covering it to avoid rain or dirt in the headlights
i have seen one with ABS all he did was move the ABS pump back and drill new mounting holes and use self tapping bolts.
also not sure what year his car was.
http://site.icbmotorsport.com/JDM_Vi...Integra_13.jpg
ai95
Mar 10, 2003 01:33 PM
