Need a manual tranny for D16y7
Old Feb 1, 2013 | 03:56 PM
dargham's Avatar
Default Need a manual tranny for D16y7
Hi there,
I have a 1999 Honda Civic LX Sedan with Manual transmission. Motor D16y7. My tranny is really starting to go down quick. Lots of screeching and rattling. Only need the car to run for another 6 months or up to a year so trying to find a used tranny to put in there. I don't know how to do it so will pay a friend of mine who is an excellent mechanic to do it.
What kind of transmission could I put in there? What models? Where could I find one? Any help would be greatly appreciated. Thanks!
Old Feb 1, 2013 | 04:52 PM
KevinVX's Avatar
Default Re: Need a manual tranny for D16y7
You can try searching for a transmission in the marketplace, Craigslist and other various places such as junkyards.
Old Feb 1, 2013 | 05:18 PM
jbpnoman's Avatar
Or just go to your local junk yard and get the transmission from any non-SI 92-00 Civic. They'll all bolt up. Just get whatever's cheapest.
Old Feb 1, 2013 | 05:55 PM
redtherocket's Avatar
you will want to get one from a sedan...
Hatches have a different final drive, 3.7 as opposed to your 4.058
If you get one from a Y8 equipped car, even better..
Final is 4.25
Old Feb 2, 2013 | 08:06 AM
dargham's Avatar
Thanks so much for the replies!
How about a 2000 EX (vtec) tranny? Would that make a difference or would that work?
Old Feb 2, 2013 | 08:09 AM
98civdx's Avatar
Master Detailer
^ that will work just fine!
Old Feb 2, 2013 | 08:14 AM
Thats about the best choice you could make..
Short gear ratio, and a 4.25 final drive...
Boo ya..
Old Feb 2, 2013 | 08:22 AM
dargham's Avatar
Thanks! EX tranny sold already How about from a 1994 VX? For $150? That worth it? Would it work?
Old Feb 2, 2013 | 08:27 AM
I wouldn't
The VX is an econo hatch... The ratios will not be the same as your sedans... And it will feel sluggish with the different ratios.
Do your best to find one from a "sedan" or one mated to a D16Y8 or D16Z6
Old Feb 2, 2013 | 08:29 AM
dargham's Avatar
Ok... again, thank you so much for all the advice! Trying to find something in the marketplace and it's messy! Ha ha. Not having much luck on craigslist either...
Old Feb 2, 2013 | 08:33 AM
98civdx's Avatar
Master Detailer
I wouldn't touch a VX transmission.
Old Feb 2, 2013 | 09:45 AM
dargham's Avatar
How about this one: SOHC NON VTEC D16Y7
WITH VSS
WILL FIT ANY D SERIES MOTOR
CAME OFF MY 2000 CIVIC DX
HAS AROUND 89,000 MILES
SHIFTED FINE NO GRINDING OR POP OUTS
It has 89,000 miles on it but seller wants $400 for it. Thoughts?
Old Feb 2, 2013 | 10:38 AM
WITH VSS
Ask the seller if the transmission is out of a "hatch" or "Coupe"
I'm not to familiar with state side trim levels..
Here is a transmission gear ratio chart... Use the table to find what suits you best...
http://www.geocities.com/bing_bong916/trannyspecs1.html
Old Feb 2, 2013 | 10:42 AM
dargham's Avatar
Ok, I'll ask him. Transmission says E7F P4A on one side of it. On other side it says S40 2006683. Does that help?
Old Feb 2, 2013 | 10:56 AM
The code E7F P4A is followed by more numbers..
Should look like this...
E7F-P4A-A000 or B000
A000 is from a D16Y7... But the Code still does not tell you which final drive the car has... Only knowing if it was out of a hatch or coupe can tell you.. Or you need to take it apart..
B000 is out of a D16Y8... It is better in more ways than just the final drive and short ratios... I believe the cases bearing are heavier...
Not saying you need the better trans... Just saying if you have an oppurtunity to get one, its worth the extra $50-$100 over the more generic ones..
Old Feb 2, 2013 | 02:22 PM
dargham's Avatar
Was taken out of a coupe... what do you think?
Old Feb 2, 2013 | 02:45 PM
Sounds good..
Should be the same as the one in your car or better..
Old Feb 2, 2013 | 02:48 PM
dargham's Avatar
and $400 sounds good?
Old Feb 2, 2013 | 02:56 PM
PanchoEK's Avatar
i've had a vx transmission.. may not be the best,but saves you a lot of money in gas... 65mph on highway at only 1800-2000rpm!!
cant remember exactly but i wouldnt mind a vx transmission
Old Feb 2, 2013 | 03:02 PM
Seems a bit steep, but it is low miles and exactly what you need...
I'd offer $250... Go from there..
Old Feb 2, 2013 | 03:03 PM
dargham's Avatar
Ok, thanks again for the help! I really appreciate it
Old Feb 2, 2013 | 03:10 PM
Hope it works out for you..
Don't neglect your clutch..
dargham
Transmission & Drivetrain
Feb 3, 2013 08:09 AM
norurb
Mar 12, 2009 11:35 AM
bosco500
Jun 18, 2006 09:49 AM
w
11
Apr 20, 2005 09:01 AM
a1320honda
Sep 12, 2004 07:43 PM
