JDM Cluster Help
Old Oct 20, 2002 | 10:32 PM
Unlimited's Avatar
New User
Default JDM Cluster Help
i have a problem with my JDM ITR Cluster it wont plug straight into 2000/2001 ITR's
i'm pretty paranoid about switching the JDM Gauge Faces onto the 2000/2001 ITR circuit board
i've tried and have broken some clips already but otherwise the cluster isnt busted
whats the best way to pry apart the gauge faces from the circuit board
i wonder if spoon clusters plug into 2000/2001 ITR's w/o swapping the circuit boards
Old Oct 20, 2002 | 10:33 PM
itr-j's Avatar
Default Re: JDM Cluster Help (Unlimited)
fly to japan and get them to do it since they seem to have made it
Old Oct 20, 2002 | 10:36 PM
B2FiNiTY's Avatar
Default Re: JDM Cluster Help (itr-j)
Swap the guages. Easy as cake.
Old Oct 20, 2002 | 10:37 PM
Reid's Avatar
Global Moderator
Remove 3 screws holding in gas tank gauge.
Remove 3 screws holding on tach.
Remove 4 screws holding on speedometer.
Remove 3 screws holding on water temp gauge.
Remove 3 screws holding on gauge cluster bezel.
Once you've removed all of those screws, simply disconnect all the tabs and the cluster will split into two parts.
I recommend you split the cluster with the gauge faces facing to the ground.
From there it is just a matter of swapping the actual gauges and then snapping the cluster back together and putting all the screws back in.
If you have any more questions, feel free to IM me.
Old Oct 20, 2002 | 10:40 PM
Type R's Avatar
Default Re: JDM Cluster Help (Reid)
dang, the walking helms guide.
nice reid
Old Oct 20, 2002 | 10:42 PM
Reid's Avatar
Global Moderator
Default Re: JDM Cluster Help (Type R)
No, that's sgT.
I'm more like the crappy Chiltons manual that has some info, but doesn't seem to have the info you want when you really need it.
Old Oct 20, 2002 | 10:43 PM
Type R's Avatar
No, that's sgT.
lol
Old Oct 20, 2002 | 10:53 PM
B2FiNiTY's Avatar
Notepad time.
Old Oct 20, 2002 | 11:24 PM
itr-j's Avatar
Default Re: JDM Cluster Help (ExOdy)
u sure it works
Unlimited's Avatar
New User
damn i never thought about removing the screws to the 3 screws holding on tach, 4 screws holding on speedometer, 3 screws holding on water temp gauge, 3 screws holding on gauge cluster bezel.
cuz i remember on EK ones you can split them without unscrewing anything...
HONDA TECH GUYS RULE MAN
Old Oct 20, 2002 | 11:31 PM
rockwilda's Avatar
No, that's sgT.
don't forget the crappy but extremely simplified and useful pics..ie: your jdm tail light pics i always use
Old Oct 20, 2002 | 11:38 PM
Unlimited's Avatar
New User
Default Re: JDM Cluster Help (rockwilda)
finally got it thanks
[Modified by Unlimited, 1:28 AM 10/21/2002]
Old Oct 21, 2002 | 10:37 AM
Reid's Avatar
Global Moderator
Received an IM on this subject, so just wanted to add a little more clarification.
No recalibration of the gauges is necessary because this is not a swapping of needles or gauge faces, but rather a swapping of the entire gauges themselves.
This is one of those things that sounds much more complicated than it really is. Once you get the cluster opened up, it's clear what needs to be done.
SC2.2CL
Mar 29, 2006 11:03 AM
People_Mover
Oct 23, 2002 12:56 PM
Mikeveli
May 29, 2002 01:33 PM
uNF$@#!
May 22, 2002 07:13 PM
