Replacing Head Gasket - what else should I replace?
I did my intake & exhaust manifold gasket too. My machine shop wants the cam taken out of the head before they mill it flat, so you might as well do valve stem seals while your in there.
All of your Coolant will be drained, so you might as well replace the thermostat while you are at it. Also, I would replace the Valve cover gasket and spark plug seals.
So far,
Intake manifold Gasket
Exhaust Gasket
Water Pump w/gaset
Timing Belt
Timing Belt Tensioner
Thermostat
Valve Cover Gasket kit
So far,
Exhaust Gasket
Water Pump w/gaset
Timing Belt
Thermostat
rasta420
May 15, 2003 07:05 AM
