5x114 and 5x112
no. it may physically fit, but rims are tapered and you use tapered lug nuts to help center the rims and hold them in place. if they are offset 2 mm, it MIGHT fit, but then the taper will be off and you'll destroy the lug and the rim. ive heard of wobbly lugs before, where you replace your lugs with lugs that move around a bit, not sure how much i trust those. I wish VW used a normal bolt pattern, because i love the newer GTI wheels.
Teamdiesel
Mar 5, 2007 07:18 AM
Boosted-LS
Apr 11, 2004 12:10 AM
