Wheel/tires from 95 Civic compatible with 00 Civic?
I have a Honda 2000 Civic and have an opportunity to buy rims and tires for it cheap. The only problem is the wheels are from a 95 civic and are 13". Will this be a problem for my car? I don't know what the exact tire size is on the 13" rims, but I want to make sure there is a size that would be compatible. Thanks
Google: Tire Size Calculator
165/70R13
Diameter Difference: 5.76%
Speedometer Difference: 6.119% too fast
Yeah no. You aren't going to be able to find a compatible tire size for a 13" wheel.
165/70R13
What is the trim of your civic? (Ex, dx, etc) My 96 dx hatch came with 13" wheels but I don't believe the 13" will clear an EXs larger caliper setup.
175/70R13 will give you the correct outside diameter.
If you have a hatchback, DX coupe or DX/VP/SE sedan 13" wheels will clear. If it's an LX/EX/Si they wont clear the front brake calipers.
88CRX951
Mar 22, 2010 01:08 PM
