91 dx water in oil and oil in spark plug tubes
Old Jan 31, 2013 | 08:47 PM
lolcode's Avatar
Default 91 dx water in oil and oil in spark plug tubes
As the title says the problem, any idea what seals need to be replaced or the cause of the problem? Also I know there is pressure building in the crank casing popping plug 1 and 4's wire up. Any help with my problem will be much appreciated.
Old Feb 1, 2013 | 09:32 AM
sde780's Avatar
Default Re: 91 dx water in oil and oil in spark plug tubes
Water in oil = cracked head, blown headgasket, or cracked block. Oil in spark plug tubes can be due to excessive crankcase pressure stemming from blow-by or spark plug tube seals need replaced.
spinnergee
Jul 5, 2010 02:40 PM
1995Civiccx
Sep 21, 2007 02:19 PM
janz3n
18
Apr 20, 2006 06:34 AM
briq4
Aug 8, 2001 04:47 AM
