What trans for 95 H22 Accord
Old Jan 31, 2013 | 08:33 PM
gary95H22Accord's Avatar
Default What trans for 95 H22 Accord
Doing my auto/manual swap this summer. I am looking for H22 transmissions. Will the 98+ transmissons (like the USDM Prelude base M2Y4) fit in the 94-97 chasis? Or do I need to stick to 92-96 and 94-97 type transmissons. Thanks guys.
Old Feb 1, 2013 | 06:05 AM
spoon3rdgen's Avatar
Default Re: What trans for 95 H22 Accord
the 5gen prelude tranny will work also but you have to tap the transmission mounting points. the 95 accord uses a different bracket then the 5gen tranny.
Old Feb 1, 2013 | 06:55 AM
nus_dogg's Avatar
No, you do not need to tap anything. Just re-use the Accord 5spd mount. All 93-01 H22 5spd trans will work in his 95 Accord. The only time you'll need to tap and move the bracket studs from the housing over to the new holes is if he's going to use the 93-01 H22 trans into a 90-93 CB7 Accord. Those have different stud patterns on their trans. I have a T2T4 LSD trans from a Accord SiR-T, and it fits just fine in my Accord by re-using my old Accord 5spd mount. No tap needed.
OP, the trans I recommend you getting would be any M2F4(USDM), M2Y4(USDM), M2A4, M2B4,T2T4 LSD, or the almighty T2W4 LSD Euro R trans. As long as you have a short geared ratio trans, your H22 would be running at it's full potential. Just watch out for the 3rd and 5th gear when you're looking to buy locally used H22 trans. Those are notorious for grinding.
Old Feb 1, 2013 | 09:21 AM
Thanks for your help Nus_Dogg!! This makes looking for one a lot easier!
Old Feb 1, 2013 | 06:48 PM
nus_dogg's Avatar
No problem.
When I had my F22B1 trans mated to my H22A, my car is so slow. It's as fast as a Delsol with a JDM B16A. I ran against my buddy's and was side by side, thats how I know. Lol. Once I got my T2T4 LSD trans, and it was night and day difference in acceleration. Dust RSX Type S and Civic Si, and mine was has only I/H/E untuned at the time.
Civicfanatic_09
Oct 18, 2009 06:10 PM
Civicfanatic_09
Oct 18, 2009 05:33 PM
97civicsedan
Nov 27, 2005 04:45 PM
95accordh22a
Feb 17, 2005 12:06 PM
