B18a1 from 1993 gs into 91
Old Jan 31, 2013 | 07:12 PM
DaIntegra1991's Avatar
Default B18a1 from 1993 gs into 91
so long story short i have to pull motor out of my 1993 integra because i snapped the subframe and shell is rusty anyways, i picked up a rust free 91 shell that had the motor and tranny pulled. the 1991 still has the main harness but no engine harness.
Question is will my b18 from the 1993 just hook right up or do i need a Obd1-obd0 jumper harness?
What else would i need?
thanks
Old Feb 2, 2013 | 02:23 PM
Default Re: B18a1 from 1993 gs into 91
just bought a rywire obd0-obd1 jumper harness.
is there anything else that i am going to need?
please help thanks
Old Feb 2, 2013 | 06:41 PM
See_5's Avatar
I think you need to ecu from the 93 also.
Old Feb 2, 2013 | 07:08 PM
ya i planned on useing the ecu fromthe 93 thanks, i just didnt know if there if i have to pull the main harness out of the 93 and use that as well.
Will the 1991 main harness hook up to the 1993 engine harness with the rywire jumper harness? im just confused on what exactly the jumper harness is going to hook up to
Old Feb 4, 2013 | 06:16 AM
SolScifen's Avatar
Im pretty sure the jumper harness just lets you hook the obd0 engine harness to the obd1 ecu.
Id think the plugs would still hook up to eachother between the engine and main though. Not 100% sure but I don't see them changing the harness too much between years.
Old Feb 5, 2013 | 07:25 AM
acura_madness's Avatar
if you have the obd0-obd1 you should be fine.
Old Feb 5, 2013 | 07:27 AM
Also if you check on G2Ic.com they have more info on this since thats all they mess with 90-93 integra da's
therest
Nov 13, 2012 03:41 AM
bradennicely
Apr 25, 2010 04:36 PM
ekgcool
May 8, 2007 05:43 AM
D3U1LT
Jan 24, 2005 10:47 AM
josh green
Jan 20, 2005 04:19 AM
