Comparing int and ex itr valve springs
Old Jan 31, 2013 | 05:52 PM
See_5's Avatar
Default Comparing int and ex itr valve springs
I just bought a used set of itr valve springs and retainers for my GSR. They all look exactly the same. I can see paint on them but its not clear enough for me to be able to differentiate between them.
I searched around and noticed in some years they have the same part number for both. All of them look to be the same height and have traces of blue or green paint on them.
At this point i am thinking they are the same. The gsr intake valve springs i pulled out of my gsr deff. have a thinner coil and are taller. Should I just take these to a machine shop to test the spring rate? They are in better shape and are stiffer then the GSR Intake valve springs I pulled out of mine.
Heres the link I found on part numbers.
http://www.lightningmotorsports.com/techhonacua.htm
Old Feb 1, 2013 | 01:27 AM
angryhillbilly's Avatar
Default Re: Comparing int and ex itr valve springs
From what I understand, one of the sets either int or ex is a slightly taller than the other for the oem itr springs. I have also read and seen people run any combination of those 3 dual valve springs (itr intake itr exhaust, and gsr intake) and work just fine for itr cams. My buddy is currently running itr exhaust and gsr intake springs.
Old Feb 1, 2013 | 07:54 AM
m_shake's Avatar
Retainers are the same, itr has it's own intake springs(yellow) and for exhaust side it uses gsr intake springs(blue).
92integraVTECgsr
17
Jan 5, 2009 08:02 PM
92integraVTECgsr
Oct 1, 2008 12:59 PM
rough_draft
Oct 8, 2004 08:23 AM
98CivicDX
Feb 21, 2002 08:04 AM
