accord sir-t, f20b detonating
hi i hav jst purchased a 98 honda accord sir-t running a f20b sohc vtec engine.
sometimes when accelerating the engine has much less power and starts 2 detonate around 5500rpm. i plugged a diagnostic scanner in and it came up with map sensor fault so i replaced map sensor but i stil have the problem. any ideas what i should check/replace next or any1 else had this problem. im thinking it could possibly be the o2 sensor, a vacuum leak or the wiring harness tht plugs on2 the map sensor.
any help or ideas would be great thanks.
se93
Oct 11, 2002 03:06 AM
1sickaccord
Jul 23, 2002 12:29 AM
